3CX v14 - Extension Length
Discussion in '3CX Phone System - General' started by tiagomoreira, Mar 1, 2016.
  1. tiagomoreira
    Dec 6, 2015
    5
    We have a 3CX system v14 with extensions with 3 digits. We need to change now to 4 digits.
    Do we have to reinstall the whole system again and reconfigure from scratch? Is there any way to edit the config file or something like that?
    Thanks in advance!
  2. superior1
    Apr 11, 2011
    34
    I am quite sure the answer is yes, you will need to reconfigure completely.
