3CX V14 & Linksys SPA922 it's supported ??
Discussion in 'Windows' started by itgs, Oct 30, 2015.
  1. itgs
    Nov 8, 2008
    56
    I don't see more the templates for Lynksys (cisco sb) series ip phone (92X, 94X).
    Maybe this kind of ip phone are no more supported ??
    Is there any guide on how configure nat support parameters in case of remote direct extension behind nat ?
    Thank you for support
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Thank you for your email,
    I'm afraid those phones are not supported anymore, you can always find the list of supported phones on http://www.3cx.com/support
  3. itgs
    Nov 8, 2008
    56
    Thank you for your reply.
    Do you know if there is a "compatible" template I can use to replace the "ex" supported ?
    Or I need to manually configure the phone ?
    Thank you
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    No there isn't any, try in manual configuration and see if everything works as expected.
