Solved 3cx v14 Provisioning Link
Discussion in '3CX Phone System - General' started by sebd44, Jan 31, 2017.
Tags:
  1. sebd44
    Jan 31, 2017
    Hello all!
    Can you help me with this request, because support of grandstream
    request me to provisioning the link for update the firmware in the 3cx locally
    there is some folder in the URL to put it in the grandstream phone.
    Best Regards
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    Hello @sebd44
    The path to put the firmware for grandstream phones can be found at C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\xxxxxxxxxxx\firmware\grandstream
    The provisioning link can be found in the management console at the system status screen under point number 5
    Hope this helps
  3. sebd44
    Jan 31, 2017
    thanks a lot YiannisH_3CX
    i made a test with the a http request and i downdload the firmware with extension .bin
    thanks for your time
    Best Regards
