3cx V14 remote tunnel
Discussion in 'iOS' started by Drew9213, Dec 15, 2015.
  1. Drew9213
    Sep 16, 2015
    62
    I am currently unable to get the 3cx tunnel while out of office to work. All of my settings are correct as far as I can tell. All of my IP addresses are correct, my tunnel port is correct, my tunnel password is correct, I have it setup in the extension to allow use of 3cx tunnel, the 3cx for iphone is provisioned correctly and works from inside the network and it works from outside the network when 3cx tunnel is disabled. So I don't necessarily need the tunnel to work, but it's driving me crazy that I can't get it to.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    51
    Never say this if you want an answer ;-)
    Maybe an open door, but is port 5090 in the router open and forward to the 3CX server?
    Any reaction in the 3CX log file if you are trying to make an connection using the tunnel?
