3CX v14 SP2 Change time zone / ntp server
Discussion in '3CX Phone System - General' started by zcc3cx, Dec 10, 2015.
  1. zcc3cx
    Nov 29, 2015
    13
    Can not find the settings zone/ntp settings in 3cx v14. In v12 it's there.
    Mayby only possible to change is is to backup/reinstall/restore?
    Or can we change the TIME_NTP_SERVER parameter?
    Regards,
    Jan
  2. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    That was a part of the now removed phone provisioning page. Now the only way to access is through the Troubleshooting > System Parameters that it seems that you have found. Don't complain, this is progress.
  3. mercury2
    Jan 14, 2014
    That option is missing now. Where can I find the location to change Time Zone after installation?
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    During the 3CX installation you have to select your country and time zone settings.
    As far as I know is this the only posible way to select your time zone.
