3CX v15.0 Setup - Server Error
Discussion in 'Windows' started by Jack Stephen, Dec 12, 2016.
  1. Jack Stephen
    Dec 12, 2016
    I've installed 3CX and I'm getting this error on setup (3CX PBX Web Configuration Tool) after selecting the http and https ports (Creating PBX...):
    Server error
    System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary. at System.Collections.Generic.Dictionary`2.get_Item(TKey key) at _3CXCloudDBManager.CloudDBManager.RemoveCustomerInternal(String systemId, String tenantId) at PostInstall.SetupExecutor.CreateCustomerDatabase(CloudDBManager cloudDB, DBConnection masterConnection, Action`1 stateChanged) at PostInstall.SetupExecutor.CreateDatabase(Action`1 stateChanged) at PostInstall.SetupExecutor.ExecuteSetup(SetupSettings setupSettings, Action`1 stateChanged) at PbxWebConfigTool.PbxSetupService.CreatePbxInternal(SetupSettings settings)
    On the second attempt I get this error:
    Server error
    Npgsql.PostgresException: 28P01: password authentication failed for user "phonesystem" at Npgsql.NpgsqlConnector.DoReadMessage(DataRowLoadingMode dataRowLoadingMode, Boolean isPrependedMessage) at Npgsql.NpgsqlConnector.ReadMessageWithPrepended(DataRowLoadingMode dataRowLoadingMode) at Npgsql.NpgsqlConnector.HandleAuthentication(String username, NpgsqlTimeout timeout) at Npgsql.NpgsqlConnector.Open(NpgsqlTimeout timeout) at Npgsql.NpgsqlConnection.OpenInternal() at PostInstall.DBConnection.get_Connection() at PostInstall.DBConnection.ExecuteScript(String sqlQuery, IDictionary`2 parameters) at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) --- End of inner exception stack trace --- at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) at _3CXCloudDBManager.CloudDBManager.CreateCloudServerManagementDatabase(IDBConnection superuser, CloudServerManagementDatabaseConfiguration configuration) at PostInstall.SetupExecutor.CreateDatabase(Action`1 stateChanged) at PostInstall.SetupExecutor.ExecuteSetup(SetupSettings setupSettings, Action`1 stateChanged) at PbxWebConfigTool.PbxSetupService.CreatePbxInternal(SetupSettings settings)" class="ng-scope" style="box-sizing: border-box; display: inline-block; max-width: 100%; margin-bottom: 5px;">System.Exception: Error in CreatingCloudServerManagementDatabase.sql: 28P01: password authentication failed for user "phonesystem" ---> Npgsql.PostgresException: 28P01: password authentication failed for user "phonesystem" at Npgsql.NpgsqlConnector.DoReadMessage(DataRowLoadingMode dataRowLoadingMode, Boolean isPrependedMessage) at Npgsql.NpgsqlConnector.ReadMessageWithPrepended(DataRowLoadingMode dataRowLoadingMode) at Npgsql.NpgsqlConnector.HandleAuthentication(String username, NpgsqlTimeout timeout) at Npgsql.NpgsqlConnector.Open(NpgsqlTimeout timeout) at Npgsql.NpgsqlConnection.OpenInternal() at PostInstall.DBConnection.get_Connection() at PostInstall.DBConnection.ExecuteScript(String sqlQuery, IDictionary`2 parameters) at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) --- End of inner exception stack trace --- at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) at _3CXCloudDBManager.CloudDBManager.CreateCloudServerManagementDatabase(IDBConnection superuser, CloudServerManagementDatabaseConfiguration configuration) at PostInstall.SetupExecutor.CreateDatabase(Action`1 stateChanged) at PostInstall.SetupExecutor.ExecuteSetup(SetupSettings setupSettings, Action`1 stateChanged) at PbxWebConfigTool.PbxSetupService.CreatePbxInternal(SetupSettings settings)
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    357
    Hi there,
    If you have IPV6 configured on your network adapter please disable it un-install and try again. Let us know of the results
  3. Jack Stephen
    Dec 12, 2016
    Yes that did solve the problem.
  4. hamza diriej
    Feb 16, 2017
    hy i try this solution it doesn't work what can i do
  5. YiannisH_3CX
    May 10, 2016
    5,486
    357
    Hello @hamza diriej
    Are you getting the exact same error during the installation?
  6. Larry12
    Feb 23, 2017
    hi,
    I downloaded and installed 3CX, but couldn't logon to the management console. got the error below:
    "3CX Management console is not responding. This maybe be a browser issue so try to refresh or try and clear your browser cache and try again."
    and "Server error" on refresh.
    I re-installed severally with same error.
    My server has Win 10 pro as OS with enough resource to handle load.
  7. YiannisH_3CX
    May 10, 2016
    5,486
    357
    Hello @Larry12
    Please make sure that the nginx and management console service are running and try again
  8. Adil
    Mar 29, 2017
    9
    I installed 3CX V15 last night and was able to load my previous backup 3CX V12. however I'm not able to login. when I tried to login I get server error. what does this mean?
  9. YiannisH_3CX
    May 10, 2016
    5,486
    357
    Hello @Adil
    Please note that you can not go directly from v12 to V15. You need to follow the upgrade procedure so the upgrade is done correctly. You need to upgrade to V12 latest service pack then upgrade to V14 and from there take a backup and upgrade to V15. Server error can mean that you are blacklisted and need to try in 30 minutes or that the service of either Nginx or management console is not running
  10. Adil
    Mar 29, 2017
    9
    Thanks for your reply. I was not aware of these steps for upgrade and unfortunately when I installed v15 it asked me to do a backup and unstall v12. what do you suggest I do now?
  11. YiannisH_3CX
    May 10, 2016
    5,486
    357
    If you still have the v12 backup, un-install v15 and download v14. Install that and restore the v12 backup there. Once that is completed perform a a backup from v14 (save the backup to a non 3cx client). Un-install v14 and install v15 with the v14 backup
  12. Adil
    Mar 29, 2017
    9
    Thanks. can you please send me the link for v14 download.
  13. YiannisH_3CX
    May 10, 2016
    5,486
    357
    Please check your inbox
  14. Adil
    Mar 29, 2017
    9
    I have installed V14 and restored the backup from V12. and was able to get in with no problem. however I did not find a way to register so I can get the free license key and register V14. later I have backed up V14 and installed V15. and restored V14 backup. still same issue when I login. Im getting server error. to make it easy I just want the link for V14 to register and get the free license key. I dont want to use V15 for now. can you please send me the link to register V14...thx
