3CX v15.5.6354.2 Debian 9 CPU 100%
Discussion in '3CX Phone System - General' started by ucme4now, Feb 8, 2018.
  1. ucme4now
    Jan 7, 2018
    7
    I have a client with a brand new install (120+) users running on VMware v6.5, everything has been going well until recently the CPU in the VM spikes to 100% utilization and stays there. Of course this knocks all of the users off the system. This has happened twice this week around the same time frame each both days.
    I see this CRON job kick off several times prior to the CPU spike:
    CRON[31799]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Any ideas what that CRON is doing?
    When the CPU locks up this is what the log file shows that sticks out:
    "NULNULNULNULNULNULNULNULNULNULNUL" this repeats about (50) more times...
    I don't see anything obvious in the log files. Has anyone else see anything like this? Or is this more of a Debian OS issue? Generally the CPU hovers around 3-5% utilization and there is 4G of RAM with roughly 20% utilization there.
    I have other clients running the same basic config with no issues. Any and all help and feedback much appreciated.
  2. ucme4now
    Jan 7, 2018
    7
    Yes both times. Had no choice, it didn't look like the VM was going to recover on its own.
  3. ucme4now
    Jan 7, 2018
    7
    I did. I have found that is the easiest way.
  4. ucme4now
    Jan 7, 2018
    7
    The command: "man sa1" comes back with "command not found"
  5. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    If you get nothing with "man sa1," I'd suggest backup the system to google cloud and reinstall.
  6. ucme4now
    Jan 7, 2018
    7
    Interesting, I checked a couple of other recent ISO installs and the "man sa1" doesn't work there either.
  7. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Mine does. I have a standard ISO from 3CX and I've not changed a thing.
    Won't hurt to do an "apt-get install man-db" though before reinstall.
  8. ucme4now
    Jan 7, 2018
    7
    So, I just pulled the 3CX Debian ISO file down and reinstalled. No MAN pages. Am I missing something???
  9. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Strange.
    just do apt-get install man-db and move on.
  10. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    733
    112
    I assume this is part of 3CX slimming things down to be more micro cloud instance friendly.
  11. ucme4now
    Jan 7, 2018
    7
    With any luck, this is the root cause of the 100% CPU spike. The is an issue with VMware and Debian:
    https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=864642
    https://www.reddit.com/r/homelab/comments/6s5dh6/debian_9_on_esxi_65u1_complete_lockup/
    After (4) crashes this week with the fourth happening to my test unit with zero load on it, something had to give... The VMware 10G virtual driver has an issue with certain Debian releases, read the articles. Changing the virtual adapter back to the 1G e1000 seems to be the work around.
    Changes have been made and will be monitored. Hopefully everything runs clean next week because I'll be in Ft Lauderdale at the ITExpo Show!
