Solved 3cx v15.5.8291.3 SSL certificate not renew!
Discussion in '3CX Phone System - General' started by mic.max, Feb 5, 2018.
  1. mic.max
    Nov 24, 2010
    56
    I've SSL certificate not valid after 02/02/2018, automatic renewal did not happen, my maintenance expires 26/10/2018. Can you help me?
  2. mic.max
    Nov 24, 2010
    56
    can someone help me?
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,250
    202
    Best in ringing your local 3CX support number
  4. mic.max
    Nov 24, 2010
    56
    thank you! you have a italy support number?
  5. mic.max
    Nov 24, 2010
    56
    no reply on call italy support!
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Hello @mic.max
    Are you using your own or a 3CX provided FQDN? Is this a local or hosted installation?
  7. mic.max
    Nov 24, 2010
    56
    Hi, i use a 3cx provided FQDN (xxxxxxxx.3cx.it) in a local installation.
  8. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Please make sure that you can resolve activation.3cx.com and letsencrypt.org correctly when you perform an nslookup. Also did you get a email showing that your certificate did not update correctly?
  9. mic.max
    Nov 24, 2010
    56
    C:\Users\server-2.1>nslookup
    Server predefinito: xxxxx.xxxxxxx.local
    Address: 192.168.1.xx
    > activation.3cx.com
    Server: xxxxx.xxxxxxx.local
    Risposta da un server non autorevole:
    Nome: activation.3cx.com
    Address: 151.80.125.88
    > letsencrypt.org
    Nome: letsencrypt.org
    Addresses: 2001:41a8:26:18f::ce0
    2001:41a8:26:191::ce0
    104.106.96.213
    i'm not receive a mail, i see my ssl cert not valid after 02/02/2018
    #9 mic.max, Feb 6, 2018
  10. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Please send me a personal message with your FQDN so i can further look into the issue.
    mic.max likes this.
  11. mic.max
    Nov 24, 2010
    56
    i send private message
  12. mic.max
    Nov 24, 2010
    56
  13. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Glad to see the issue has been resolved
