3CX V15.5, Update 3 ALPHA is Available for You to Try Out
Discussion in '3CX Phone System - General' started by nb, Dec 22, 2017.
  1. nb
    nb Support Team
    Jun 7, 2007
    2,100
    143
    Nick Galea and comms1 like this.
  2. StefanW
    Jun 2, 2009
    1,203
    82
    to you also! See you again in 2018.
    nb likes this.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,907
    201
    @comms1 Thank you and merry Xmas to you too!
  4. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    171
    60
    "We’ve included IPV6 support, conference setup improvements for the web client, auto-enabled SSL and TLS and we’ve also added a hosting-admin account level."
    @santa! Just what I wanted for xmas!
    #MerryXmasTo3CX
    :cool::cool::cool:
    nb and Nick Galea like this.
  5. RafaelD
    Aug 24, 2017
    Great update Nicky!
    can you tell me how i can acces the hosting-admin account level?
  6. the60
    the60 New Member
    Oct 21, 2011
    117
    50
    Good stuff!!
    Nick Galea likes this.
  7. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Did you fix the recording issue?
    Can we change the queue ringtones without custom template?
    Getting this error installing on clean Debian.
    #7 jimbo59, Dec 23, 2017
    nb likes this.
  8. andreaschr
    Oct 26, 2015
    91
    6
    Probably you miss the first command of the blog
    Code:
    wget -O- http://downloads.3cx.com/downloads/3cxpbx/public.key | apt-key add -
    or wget is not installed on your system, run this to install it
    Code:
    apt install wget
    then try again
    Merry Christmas
    #8 andreaschr, Dec 24, 2017
  9. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Please read original screen shot and see that if wget wasn't installed I wouldn't have gotten that far. I did the correct commands and have wget installed.
    #9 jimbo59, Dec 24, 2017
  10. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    67
    Jimbo - check your available disk space to make sure there is enough. Odd things happen if there is not enough free space, and the errors do not always indicate this.
    After that, check 3cxpbx.list file. I had to remove the quotes to get it to run update properly.
    sudo nano /etc/apt/sources.list.d/3cxpbx.list
    Look for "deb http://downloads.3cx.com/downloads/debian stretch main" and remove the double quotes and remove them if they exist. Then Ctrl+X to exit, yes to save.
    Then, run apt-get update again, followed by apt-get install 3cxpbx
  11. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Thanks. I went ahead and ran the windows package for now. Works great. Have a nice bridge setup with sp2 (linux) and sp3 (windows).
    Love the return of conference.
  12. mtech1
    Jan 25, 2010
    26
    5
    Have you got fanvil hot desking in this release?
  13. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    It's in the drop down list.
    No custom templates for hotdesk though.
    #13 jimbo59, Dec 26, 2017
  14. nb
    nb Support Team
    Jun 7, 2007
    2,100
    143
    We will release a blog post for this - yes you are right..
    It is made via setup xml.. We will do this too. I can upload a sample template here. Send me a pm.
  15. nb
    nb Support Team
    Jun 7, 2007
    2,100
    143
    Queue ring tones is planned for SP4 !! :)
    telis and accentlogic like this.
  16. nb
    nb Support Team
    Jun 7, 2007
    2,100
    143
    In the final version it will be for sure. Now we have a firmware that does not reboot making Fanvil phones faster to login to hotdesking.
  17. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    771
    118
    Would love to see multicast paging configurable on the phone provisioning page. Still using custom templates for this as well.
    giwm, Jeremy Bero and nb like this.
  18. nb
    nb Support Team
    Jun 7, 2007
    2,100
    143
    Even this we gonna make.. V easy.. SP4 both of them together.
    cobaltit likes this.
  19. cobaltit
    Mar 22, 2012
    771
    118
    Great news. I'm not sure on how you think best to implement but keep in mind scenarios using Cyberdata to do the multicast vs coming directly from 3CX so the field needs to be configurable in some way to achieve that.
  20. poynter.net
    Aug 26, 2009
    28
    Have you got more information on the TLS setup? Does this use the LetsEncrypt certificate? Do the phones need to connect via xxx.3cx.xxx rather than the internal IP address?
    Also to enable SRTP is this only done on the phone interface or can the provisioning template be adjusted.
    Will there be any status displayed on the management console for the phones and SIP Trunks?
    #20 poynter.net, Jan 3, 2018
    dkeethler likes this.
