3CX V15 and old Cisco SPA 92X - 94X
Discussion in '3CX Phone System - General' started by itgs, Feb 17, 2017.
  1. itgs
    Nov 8, 2008
    58
    I have some old Cisco SPA922 and 942 that are connected with my recently updated 3CX V15.
    All is working but I noticed that are ip phone no more supported.
    In the "Phone Provisioning" section there is "3CX Client" indicated in "Your Phones" configuration of the extension (see attached image).
    Is it all ok or there is something I have to know (or to do) ?
    Thank you for supporto
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
    Hello @itgs
    Since the phones you are using are not supported there is no template for those phones and since you manually registered them then they will not appear under the Phone Provisioning tab in the extension settings. So this is normal
  3. itgs
    Nov 8, 2008
    58
    Thank you Yiannish for your reply.
    Do you suggest to disable autoprovision configuration in the phone ?
    Thank you
