Solved 3CX v15 and Polycom IP 550
Discussion in '3CX Phone System - General' started by Wolfraider, Jun 2, 2017.
  1. Wolfraider
    May 30, 2017
    7
    We are running 3CX v15 and have several Polycom IP 550's. They phones provision fine but we cannot call out. We get a busy signal when trying to call other extensions or voicemail. Inbound calls work fine. The phones are running firmware 4.1.0.84959.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
    Hello @Wolfraider
    Are these phones provisioned as local extensions to the PBX using the default templates? Are the phones and the PBX in the same network ?
    Have you tried enabling PBX delivers audio under extension settings and see if that makes a difference?
  3. GCollis
    Dec 11, 2014
    39
    6
    Have you looked at the dial plan on the polycom 550?
  4. Wolfraider
    May 30, 2017
    7
    Local extensions with the default template
    same network
    I checked the PBX delivers audio and no difference
    Digit Map is empty on the phone
    I'm going to do a wireshark to see if the phone is trying to send any packets out when trying to call
  5. Wolfraider
    May 30, 2017
    7
    Tried a different phone and it worked fine. Looks like for some reason I have a dead phone.
  6. StefanW
    Jun 2, 2009
    1,222
    93
    format Polycomes file systen (not just reset) and boot it up with DHCP option 66, it will reload the sip firmware and provision. does this solves the issue???
  7. Wolfraider
    May 30, 2017
    7
    That fixed it, thank you
  8. StefanW
    Jun 2, 2009
    1,222
    93
    welcome!
