3CX V15 - AudioCodes MP-114 FXO - Registration Error
Discussion in '3CX Phone System - General' started by vwadher, Dec 20, 2016.
  1. vwadher
    Mar 11, 2007
    17
    Here is the error message. I've enabled the FXO (PSTN) Trunk to register to this PSTN gateway by using the "Do not require - IP Based" auth. Reason I had to do that is because I was just not able to get the Trunks to register and light up Green. Also for some reason the only way I could register the 4 lines on this gateway device is by registering EACH line (even though its on the 1 gateway) multiple times on the 3CX Trunks Area. So I've got 4 trunks registered on the 3CX Trunks area, even though its really all connecting to 1 gateway device.
    Here is the log with the error - Other than this error in the log, the calls randomly drop - please help!
    12/20/2016 12:37:19 PM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.2.16:5060 tid=ac129736812 Call-ID=1674803971120000023@192.168.2.16: REGISTER sip:192.168.2.6 SIP/2.0 Via: SIP/2.0/UDP 192.168.2.16;branch=z9hG4bKac129736812 Max-Forwards: 70 Contact: <sip:10006@192.168.2.16>;expires=180 To: <sip:10006@192.168.2.6> From: <sip:10006@192.168.2.6>;tag=1c129416720 Call-ID: 1674803971120000023@192.168.2.16 CSeq: 91174 REGISTER Expires: 180 Allow: REGISTER, OPTIONS, INVITE, ACK, CANCEL, BYE, NOTIFY, PRACK, REFER, INFO, SUBSCRIBE, UPDATE Proxy-Authorization: Digest username="10006",realm="3CXPhoneSystem",nonce="414d535c0e6a196f62:fe1a705cbfb545c529750beb25c5e100",uri="sip:192.168.2.6",algorithm=MD5,response="a0446cdd4b6ef67c181ddae5bb0dfca4" Supported: em, timer, replaces, path, resource-priority User-Agent: Audiocodes-Sip-Gateway-MP-114 FXO/v.5.20A.043 Content-Length: 0 ;
    Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
