3CX v15 don't forward DTMF when internal.
Discussion in '3CX Phone System - General' started by zccit, Aug 29, 2016.
  1. zccit
    Apr 22, 2013
    12
    Situation:
    3CX v15
    Phones
    Door stations Axis
    Goal:
    Call Door Station, push DTMF code, open a gate.
    Problem:
    When a extention is extern, the DTMF codes are send to the Door Station
    When a extention is intern, is seems 3CX server is not forwarding the DTMF tones.
    We do a lot of configurations, codecs, phone devices, BRIA apps, .... same result
    Help
    See also a drawing somebody made a while ago.
    [​IMG]
    Regards,
    Jan Mourik
    ZCC-IT
  2. jed
    jed New Member
    Feb 1, 2010
    145
    42
    Hi Jan
    Try to change the extension Options for your Intercom to let PBX Delivers Audio..
    /Jesper
  3. leejor
    10,750
    285
    It may also be a DTMF setting that has to be changed (one end or the other). In many cases, a SIP message (of the DTMF tone) can be sent, and that will work. Some devices, on the other hand, want the actual DTMF (audio) tone, which may require a settings change. Some Codecs don't handle DTMF audio very well, especially some low bit-rate Codecs.
  4. zccit
    Apr 22, 2013
    12
    Thanks for the reply's,
    We are still investigating.
    Tips welcome :)
    Regards,
    Jan
