3CX V15 is missing a .js file
Discussion in '3CX Phone System - General' started by ITWorksJimmy, Jan 16, 2017.
  1. ITWorksJimmy
    Jan 16, 2017
    Specifically in the web portal, if I try to edit a config file from the phone page, it brings up the editor but I can't edit anything. At first I thought this was intentional but then I found I can't edit templates from within 3CX either.
    Opening Chrome Developer tools I get an error that worker-xml.js is missing. Navigated to "C:\ProgramData\3CX\Data\Http\wwwroot\ace-plugins" and worker-xml.js is missing.
    Checked 3 other 3CX v15 installs and it's missing on those too...
    Does anyone have that file? Tried reinstalling and it doesn't fix the issue.
    (Version 15.0.60903.0)
  2. dab
    dab
    Nov 1, 2009
    67
    I think that you can only edit copies of templates.
    Try this, copy a template and then try to edit it. It's working for me, the original one not.
  3. ITWorksJimmy
    Jan 16, 2017
    Weird. That seems to work
    I've applied the config and I've got the "(Custom Template)" message next to the phone but it still doesn't let me edit it using the "+Config" Option... And still doesn't explain the missing xml worker file (which looks like it is designed to let you edit xml files from a browser...)
