3CX V15 Sample Bulk Import CSV
Discussion in '3CX Phone System - General' started by xirgo, Nov 9, 2016.
  1. xirgo
    Nov 9, 2015
    22
    Hey guys,
    I'm looking for a sample BULK Import CSV for the new V15
    The only searches I can find for this come up for version 14 and earlier via this link
    http://www.3cx.com/blog/docs/bulk-extension-import/
    Would anyone be able to provide me a sample of the minimum fields required for the import?
    Thanks!
  2. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    Create an extension
    Export this extension
    You will end up with your sample. Then copy for the other extensions using the exported data.
    There is a blog post online somewhere.
    http://www.3cx.com/blog/docs/bulk-extension-import/ (we will update for v15)
  3. xirgo
    Nov 9, 2015
    22
    Hey Nicky!
    This is what I had done but wanted to know which fields were required fields and which weren't.
    For example if we leave the password field empty will 3CX automatically provision a password for the extension?
