3CX V15 Sangoma Support
Discussion in '3CX Phone System - General' started by Luis Londono, Nov 15, 2017.
  1. Luis Londono
    Aug 7, 2017
    15
    We are looking to upgrade our 3CX Phone system from v14SP3 to the latest V15. Ahead of us doing this I wanted to confirm and see if anyone is aware of any issues with using a Sangoma PRI A101 T1 Card?
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,408
    186
    Hi Luis,
    If you have not already purchased the Sangoma card I would not do this and purchase a "supported" gateway instead. Historically there was a partnership between Sangoma and 3CX but this is no longer:
    https://www.3cx.com/voip-gateways/
    You will see the same from this forum post here:
    https://www.3cx.com/community/threads/configuring-sangoma-pri.9444/
    Like the above forum link I would personally recommend the Patton boxes, they are most excellent and support auto-configuration from 3CX:
    https://www.3cx.com/voip-gateways/patton-sn4940-sn4950-sn4960/
    YiannisH_3CX likes this.
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,582
    238
    @Luis Londono
    So Sangoma products work fine. If you already have it configured/working in v14 it will continue to work just fine. They are no longer supported by 3CX but I believe that was more of a business decision than technical. Sangoma has a very good track record with their PRI cards.
