Solved 3CX v15 Softphone Outgoing Call not working
Discussion in '3CX Phone System - General' started by Hitcher99, Mar 21, 2017.
  1. Hitcher99
    Mar 21, 2017
    5
    we are using the latest 3CX V15 Version.
    We are facing since the latest Update (3CX Phone System v15 SP5, Build 15.0.62928.5)
    an issue with the 3CX iPhone & Android Clients.
    We cant make any Calls from an External IP (4G / 3G) Call.
    If i test it from the Corperate Network it works fine.
    Anyone an Idea?
  2. CBUTLER
    May 11, 2015
    52
    Have you configured your firewall properly?
    • Port 5090 (inbound, UDP and TCP) for the 3CX tunnel
    • Port 443 (inbound, TCP) HTTPS for Presence and Provisioning
      (Unless you have chosen custom ports).
    • Port 443 (outbound, TCP) for Google Android Push:
    • Port 2195, 2196 (outbound, TCP) for Apple iOS Push
  3. Hitcher99
    Mar 21, 2017
    5
    Hello the Ports are correct and also checked with the firewall tester.
    No Problems with the Ports.
  4. pagsinc
    Oct 13, 2016
    9
    We are having a similar issue.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,340
    533
    Hello there,
    When you open the app outside the network does the app register? Are you able to see presence?
    Is tunnel enabled under the extension settings? Try sending a new welcome email to the users and see if that works for you. Also make sure that under extension settings / options the option Block remote tunnel connections is not enabled
  6. Hitcher99
    Mar 21, 2017
    5
    the app register works without any problems also i can see the presence but i cant make any call at all.
    If i try to call anyone i recieve diretcly: "forbidden" and thats it.
    Also the Extension is looking good.
    [​IMG]
    I also tried a reprovisioning no chance at all.
    Also the Windows Client cant make any Calls from External since the latest Update. :( :(
  7. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Hitcher99,
    Did you check on your Server Activity Log?
    Also please make sure that the Local SIP domain is the same with your FQDN and please let us know.
    Settings =>Network =>FQDN
  8. Hitcher99
    Mar 21, 2017
    5
    i see the register on the LOG:
    Log:
    Extension 2802 is registered, contact: sip:2802@100.78.226.59:50195;transport=TCP;rinstance=1-2fygphqftpwsfev4w5fl3cgoypv9jtpu;ob;inst="fd6469f5"
    Activity Log:
    03/23/2017 12:27:16 PM - [CM302001]: Authorization system can not identify source of: UnkSrc Recv Req SUBSCRIBE from 127.0.0.1:5080 tid=PjCvqBHpJZbarwbAnVNG4e3XZ1aO8rd54v Call-ID=zAAJCbE.eN2UY9LrYAx9ia3mm4yXJtrx: SUBSCRIBE sip:2802@127.0.0.1:5070 SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjCvqBHpJZbarwbAnVNG4e3XZ1aO8rd54v;rport=5080 Via: SIP/2.0/UDP 109.84.0.43:41014;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.1-emv9xmdu0w4vnxze6v36enyra.ebrrm2 Via: SIP/2.0/TCP 100.78.226.59:50195;rport;branch=z9hG4bKPjCvqBHpJZbarwbAnVNG4e3XZ1aO8rd54v;alias Max-Forwards: 69 Record-Route: <sip:3cxBridge@127.0.0.1:5080;user=proxy;uri=clnt.1-emv9xmdu0w4vnxze6v36enyra.ebrrm2> Contact: "William Harrell"<sip:2802@100.78.226.59:50195;transport=TCP;rinstance=1-emv9xmdu0w4vnxze6v36enyra.ebrrm2;ob;inst="fd6469f5"> To: "William Harrell" <sip:2802@ixtech.3cx.de:5070>;tag=5435c079 From: "William Harrell" <sip:2802@ixtech.3cx.de:5070>;tag=md7hPaUDqJEkkVjhRWTra1arLdoN-1Bx Call-ID: zAAJCbE.eN2UY9LrYAx9ia3mm4yXJtrx CSeq: 28083 SUBSCRIBE Expires: 0 Accept: application/simple-message-summary Supported: replaces, 100rel, timer, norefersub Event: message-summary Allow-Events: presence, message-summary, refer Content-Length: 0
    fqdn: ixtech.3cx.de
    Internal: 3cx-pbx.ix-tech.local
    [​IMG]
    #8 Hitcher99, Mar 23, 2017
  9. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Hitcher99,
    Please change the internal "3cx-pbx.ix-tech.local" to "ixtech.3cx.de", try to make a call as you mentioned above and let us know.
    Hitcher99 likes this.
  10. Hitcher99
    Mar 21, 2017
    5
    Thank you very much!
    Now the Calls are working again. Inbound & Outbound :)
  11. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Hitcher,
    Glad to hear the issue is resolved and thank you for update the post :)
