3CX V15 SP1 - Install and SMTP Errors
Discussion in '3CX Phone System - General' started by naysan, Oct 9, 2016.
  1. naysan
    Oct 9, 2016
    I have been testing out V15 on a VM, I had some problems around SMTP mail server so I did a fresh install on a clean VM (thinking it was a problem with the original machine) but now I get the attached error every time I try to install straight after I type in the admin password.
    I also note that the FQDN entry disappeared on my account on erp.3cx.com (screenshot attached)
    The reason I reinstalled is because I couldn't get the SMTP mail server working. I followed these steps - http://www.3cx.com/blog/docs/gmail-mail-server/ to get gmail working but when pressing test nothing happens and it just times out after a while.
    I tried Office365 too and it errors with “The remote certificate is invalid according to the validation procedure”. I even tried turning Windows Firewall off completely, nothing helped.
    Any help would be appreciated!
  2. pmochalin
    Oct 7, 2016
    У меня такая же проблема.
    Устанавливаю на Windows Server 2012 R2 Essentials.
    .Net framework 4.6.2 установлен.
    VS 2015 C++ установлен.
    I have the same problem.
    Is installed on Windows Server 2012 R2 Essentials.
    .Net Framework 4.6.2 installed.
    VS C ++ 2015 installed.
    [​IMG]
  3. Baguk
    Aug 5, 2016
    13
    Seems that 3CX has issues with their Web API servers. It looks like that attempt to http://erp.3cx.com/apiv2/myip fails and therefore neither new configuration nor restore from backup could be done. This is since this morning already.
    We had plan to move 3CX to other server today, but this is not possible, as restore on new host can not be completed.
    @3CX, are here somebody who could fix the issue with http://erp.3cx.com/apiv2/myip on Sunday?
  4. Baguk
    Aug 5, 2016
    13
    Seems to be fixed now. :) We'll try with our migration.
  5. naysan
    Oct 9, 2016
    Ah excellent! Thanks for reply, all working now - I also got the SMTP settings working! :)
  6. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    All is good now.. API endpoint was restored.
