3CX v15 SP4 - Install - Unable to specify own FQDN
Discussion in '3CX Phone System - General' started by marcusjclifford, Jan 7, 2017.
  1. marcusjclifford
    Apr 17, 2012
    25
    Trying to do a fresh install of 3CX v15 with SP4.
    I am unable to specify my own FQDN name, with the only option being to take a 3CX provided one.
    This is the same via Web browser setup and text based. (as shown below)
    I have my own FQDN which has a publicly signed certificate that I want to use. I do not want to use a 3CX FQDN.
    What can I do?
    Marcus
  2. agp
    agp 3CX Team
    Aug 19, 2015
    140
    21
    Hi @marcusjclifford ,
    If you are using the PBX(Free) Edition then you can only use a 3CX provided FQDN.
  3. Eef Worm
    Jan 27, 2017
    And what if I need to change the external IP address after a move or so?
    Is there an option to change the IP address if needed or do I need to install a new PBX, while the external IP is also in the backup file off-course?
  4. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    V15 will update dynamic IP.
  5. Eef Worm
    Jan 27, 2017
    Thank you very much for your reply!
    So when I choose the Dynamic IP option in Wizard you mean, or also when I choose the Static IP?
