3CX v15 SP4 Linux and G729 channels
Discussion in '3CX Phone System - General' started by cobaltit, Dec 12, 2016.
  1. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,783
    282
    Are all channels unlocked now? On the license settings page it still shows half for G729 channels.
  2. andreasc
    andreasc Guest
    Yes.
    When logging into the Management Console/Settings/License, you will notice that the Number of G729 Channels will still show half, however, this does not affect the functionality.
  3. cobaltit
    Mar 22, 2012
    1,783
    282
    Ok, thank you for confirming
