3CX v15 SSL Cert is not working
Discussion in '3CX Phone System - General' started by Steven.Zhang, Oct 16, 2017.
  1. Steven.Zhang
    Oct 16, 2017
    10
    Hi All,
    i recently installed a 3cx v 15 phone system on server . I input a SSL Cert during setup and also put in password. But after the server is installed , it appears the SSL cert is not working (webpage shows it is not secured and red slash on https).
    Is there anyway to replace the SSL cert which is being used in the management console?Or is there any configuration i need to add after the installation?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
