Solved 3cx V15, under windows, Cisco 7940 message/voicemail acces via key issue
Discussion in '3CX Phone System - General' started by cmdias, Feb 27, 2017.
  1. cmdias
    Feb 13, 2017
    31
    Hi guys,
    I have a setup with two old cisco 7940 phones... all works great except voicemail access via the phone's key...
    by defdault it was dialing *97 ... changed it to *4 in the phone's cfg file but nothing... *4 seems to work when i dial it manually..
    I just gent a busy signal in both cases and a reorder message.
    any ideas ?
    #1 cmdias, Feb 27, 2017
  2. GiannosC_3CX
    GiannosC_3CX Guest
  3. cmdias
    Feb 13, 2017
    31
    all direct calls/options work... just vias the message key that i get a reorder/busy signal...
    tried in my phone ocnfig file :
    messages_uri: “*97” and messages_uri: “*4” ...
    any other ideas ?
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi cmdias,
    We replicated you issue and your settings look correct. Please make sure on the dial codes tab field "Connect to voicemail of extension " is *4 or *97. Also, please check on settings => voicemail => "Voice Mail Menu Extension Number" what extension number does the system use and try to call the voicemail directly. Next please make sure that the phone is provisioned with the correct xml.
  5. cmdias
    Feb 13, 2017
    31
    great... changing the setting int the voice mailmenu back to *97 works!!!!!
    I just dont know whe ehrn i had *4 at bothe palces (the phone config and in the voice mail menu setting) it didnt work.
    but thank you!!!!
  6. GiannosC_3CX
    GiannosC_3CX Guest
    hi cmdias,
    Glad to hear the issue is resolved.
