3CX v15 upgrade from v12
Discussion in '3CX Phone System - General' started by safemode, Sep 2, 2016.
  1. safemode
    Jan 17, 2010
    22
    I am just trying to clarify whether you can upgrade straight from v12 sp6 to v15 v6, it says in the documentation that you can skip a major version, and I am not sure if 12.5 was considered a major version or not
    regards
    Anthony
    10,752
    285
    Not sure, but, you'd be skipping two, 12.5 (first 64 bit version), and 14.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    You can do V12 latest serivce pach to V14 and then V15 or V12 latest service pack to V12.5 latest service pack and then V15.
    V12.5 and V14 are major releases.And you cannot skip 2 major releases
  4. Ron Holtby
    May 25, 2017
    I was told from 3CX support you can upgrade from v12.5 to v15 however you will lose call history if you don't move to v14 first. If you don't care about call history then you can upgrade directly from v12.5 to v15.
  5. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    You can go from 12.5 to 15 and there's a tool to convert the call history.
    dataIT likes this.
  6. Razva
    May 7, 2017
    30
    Why not make a fresh install? I've also tried to upgrade from a previous version and it was a mess.
  7. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    As in not use a backup at all and reprogram from scratch ?! ... ive done hundreds of upgrades with no issues 99% Of the time.
    jbryant84 likes this.
  8. Razva
    May 7, 2017
    30
    I'm not an expert, so I may be wrong. In my (small!) environment it was far more easy to start from scratch and keep the old install for archiving purpose. Again, my experience/knowledge is limited, it was just an opinion. :)
