3CX v15 / Yealink t21pe2 / French provisionning
Discussion in '3CX Phone System - General' started by cmdias, Mar 7, 2017.
  1. cmdias
    Feb 13, 2017
    36
    HI guys,
    My test setup :
    3CX v15 / Yealink t21pe2 / Phone French provisionning
    Can we change the text that displays above the buttons on the phone ?? i cant seem to understant how to get this done when my phone are in french..... via the templates cant seem to find anything....
    English:
    History/3cx Pbook/DND/MENU
    French:
    Journal/3cx pbook/indisp/menu
    just wondering... might want to add some custom text in there.
    thx!
  2. cmdias
    Feb 13, 2017
    36
    language file for the yealink seems the direction that i have to look into... but cant find a lot of info for it....
  3. cmdias
    Feb 13, 2017
    36
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Yes changing the text beyond what's in the different Yealink language options would involve making your own Yealink language file, which isn't very complicated... although I find Yealinks translations are decent (with the exception of a few prompts which haven't been translated at all).
  5. cmdias
    Feb 13, 2017
    36
    I agree Jason, but still this customer asked if i can find a way to try and fit more text in the visible part.... i'm not at the office now but one of the options was "fin d'appel" i think... so we could just use "FIN"
    have you dont this language file before? how was the provisioning?
  6. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    I've done it, and I even wrote some of the translations that are in the current french language files. It's easy as long as you have the original french file - then you just tweak it the way you like it. However I can't find the original anymore (it's been a while) - You'll need to ask Yealink or your Yealink Distributor (who will end up asking Yealink).
