- Joined
- Dec 11, 2012
- Messages
- 25
- Reaction score
- 0
I have provisioned a YL T46 successfully. The account is however not registered.
I have set a unique SIP Port 5062 both on 3CX and in the phone. This port (TCP / UDP) is forwarded in the router to the IP of the phone. Als the RTP Ports (UDP 9000-9014) are forwarded.
Username, Auth-ID are "110", Password is correct. Transport protocoll is UDP.
What can be the reason of being not able to register?
I would generally use TLS. Which port hast to be used for it.
Do I understand correctly the each phones have to have unique SIP and RTP Ports, correct?
Thank you very much for your feedback.
Best regards
I.
Best regards
I.
