3CX V4 Fax Support
Discussion in '3CX Phone System - General' started by rnoguera, Oct 25, 2007.
  1. rnoguera
    Oct 25, 2007
    89
    I have setup 3CX V4 using a Patton 4554 ISDN PSTN Gateway.
    I can receive incoming faxes succesfully, but I cannot start a T.38 fax call from a 3CX extension. Gateway config has been slightly "hand" modified.
    When I try this:
    FAX MACHINE > SPA 2100 Analog Adapter > 3CX > PATTON 4554 > PSTN
    The fax calls are succesful if I use G711 "passtrough". But when I allow SPA2100 to use T.38, calls are droped as soon as the SPA 2100 detects it is a fax.
    Maybe T.38 is still not supported to place calls from an extension?
    Is there a way to send faxes using the integrated 3CX V4, or fax support is "receive only" right now?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,939
    250
    The T.38 fax has to be enabled on the Patton Gateway. Then, any call that is a fax will be forwarded to our fax service. You can also forward all calls on a particular line to the fax extension on 3CX - will then receive it as a fax.
    As for outbound only - not sure if this should effect 3cx since we dont handle it. Does the SPA2100 drop the call or does 3CX drop the call?
  3. rnoguera
    Oct 25, 2007
    89
    In the configutation for the PATTON Gateway generated by 3CX we find these lines:
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    profile voip fax_enabled
    fax transmission 1 relay t38-udp
    But the "fax_enabled" voip profile is not used afterwards, when the SIP interfaces are created. "default" is used instead:
    interface sip sipif0
    bind gateway sipgw0
    service default
    Is this a mistake or this is correct?
