3cx v8 with the VAD
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 7, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Will the VAD deploy o 3CX v8? Or do I need to wait before upgrading so the VAD will still work?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    The next release of the VAD will only work with 3CX v8. It will be released during the next days.
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    If I did a backup and restore will the old already deployed ivr application get transfered to v8?
  4. VAD_Support
    Aug 6, 2009
    690
    When restoring the database to 3CX V8 you will have the digital receptionists created for your VAD application. But maybe you have to manually copy the files in "C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\ivr\ProjectName_BuildNumber" from v7 to v8, not sure about this, I need to check this.
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    OK, thanks.
