3CX V9 working with Mediant 600
Discussion in '3CX Phone System - General' started by salemgkn, May 30, 2011.
  1. salemgkn
    May 30, 2011
    6
    Hi everybody,
    I am trying to configure a Mediant 600 1 E1 as gateway for 3CX V9 and I am having headeach fixing it. As you know it is not difficult to add a PTSN device with 3CX. I have done it and the 3CX server has generated a Virtual Extension 10000 and password and all that go with an account for the 30 channels (E1). My problem is how to configure the mediant to be registered on 3CX. I have allready done it with Audiocodes MP118 FXO succesfully but now it my first time to configure ISDN device with 3CX.
    If some of you had dealed with 3CX and Mediant 600 1 E1 please share your experience with me. I am in trouble I need your help.
    Salemgkn
  2. salemgkn
    May 30, 2011
    6
    Hi guys,
    May be this will help you find some solution for me. Here is attached what I getting on the 3CX server.
    Salemgkn
  3. hainesk967
    May 23, 2011
    38
    Registering extensions can be tricky, I know the only way I was able to get my phone to register was if I used the User ID and the Auth ID (both were the extension number) as well as the password.
  4. salemgkn
    May 30, 2011
    6
    Hi Hainesk967,
    Thanks for replying. I know that to register phones the only way is to do as you say. My problem is to register the E1 ligne with it's Virtual Extension, Authentication ID and Authentication password. I don't know to find the Authentication table in the Mediant 600. With the M118 8FXO, there is a table like the one below where you can enter the parameters generated by the 3CX for the physical lines.
    ; *** TABLE Authentication ***
    [ Authentication ]
    FORMAT Authentication_Index = Authentication_UserId, Authentication_UserPassword;
    Authentication 0 = 10004, qlubzbq;
    Authentication 1 = 10005, z7jvckr;
    Authentication 2 = 10006, e00q38e;
    Authentication 3 = 10007, p6czml1;
    Authentication 4 = 10008, ciq6w8a;
    Authentication 5 = 10009, 92p1cyw;
    Authentication 6 = 10010, beylj1g;
    Authentication 7 = 10011, 4jkop4o;
    [ \Authentication ]
    If you have a working file of the Mediant 600 1 E1, please could you send it to me?
  5. chrisneal
    Nov 20, 2008
    27
    Below you will find a INI file you can load directly into a Mediant 600. I've remarked out the login information for my system. In this example the 3CX is IP: 10.0.14.3 and the Gateway is 10.0.14.70
    ;** Ini File **
    ;Board: Mediant 600
    ;Serial Number: 3131708
    ;Slot Number: 1
    ;Software Version: 6.00A.041.001
    ;DSP Software Version: 624AE3 => 600.09
    ;Board IP Address: 10.0.14.70
    ;Board Subnet Mask: 255.255.255.0
    ;Board Default Gateway: 10.0.14.1
    ;Ram size: 128M Flash size: 32M
    ;Num of DSP Cores: 12 Num DSP Channels: 60
    ;Profile: NONE
    ;Key features:;Board Type: Mediant 600;E1Trunks=2;T1Trunks=2;PSTN Protocols: ISDN CAS ;Coders: G723 G729 GSM-FR G727 ILBC ;DSP Voice features: EC128mSec IpmDetector ;Security: IPSEC MediaEncryption StrongEncryption EncryptControlProtocol ;Channel Type: RTP PCI DspCh=60 IPMediaDspCh=60 ;Control Protocols: SIP IP2IP=30 ;Default features:;Coders: G711 G726;
    ;--------- Mediant-1000 HW components ---------
    ; Slot # : Module type : # of ports : # of DSPs
    ; 1 : FALC56 : 2 : 3
    ; 2 : Empty
    [SYSTEM Params]
    PM_VEDSPUtil = '1,54,60,15'
    SyslogServerIP = 0.0.0.0
    EnableSyslog = 0
    [BSP Params]
    PCMLawSelect = 3
    TDMBusClockSource = 4
    [Analog Params]
    FXSLoopCharacteristicsFilename = 'M1K13-1-fxs16khz.dat'
    FXOLoopCharacteristicsFilename = 'M1K12-1-16khz-fxo.dat'
    [ControlProtocols Params]
    AdminStateLockControl = 0
    [MGCP Params]
    [MEGACO Params]
    EP_Num_0 = 0
    EP_Num_1 = 1
    EP_Num_2 = 1
    EP_Num_3 = 0
    EP_Num_4 = 0
    [PSTN Params]
    ProtocolType_0 = 10
    ProtocolType_1 = 0
    FramingMethod_0 = D
    FramingMethod_1 = 0
    [SS7 Params]
    [Voice Engine Params]
    CallProgressTonesFilename = 'usa_tones_13.dat'
    FaxRelayMaxRate = 3
    CNGDetectorMode = 0
    [WEB Params]
    LogoWidth = '145'
    HTTPSCipherString = 'RC4:EXP'
    [SIP Params]
    ISPROXYUSED = 0
    ISREGISTERNEEDED = 1
    AUTHENTICATIONMODE = 1
    CHANNELSELECTMODE = 1
    GWDEBUGLEVEL = 5
    REGISTRARIP = '10.0.14.3'
    USERNAME = '(PSTN Username Generated by 3CX}'
    PASSWORD = '{PSTN Password Generated by 3CX}'
    ISFAXUSED = 1
    SIPTRANSPORTTYPE = 0
    [SCTP Params]
    [VXML Params]
    [IPsec Params]
    [Audio Staging Params]
    [SNMP Params]
    DisableSNMP = 0
    SNMPTrapManagerHostName = ''
    ; *** TABLE DspTemplates ***
    ; This table contains hidden elements and will not be exposed.
    ; This table exists on board and will be saved during restarts
    ; *** TABLE PREFIX ***
    [ PREFIX ]
    FORMAT PREFIX_Index = PREFIX_DestinationPrefix, PREFIX_DestAddress, PREFIX_SourcePrefix, PREFIX_ProfileId, PREFIX_MeteringCode, PREFIX_DestPort, PREFIX_SrcIPGroupID, PREFIX_DestHostPrefix, PREFIX_DestIPGroupID, PREFIX_SrcHostPrefix, PREFIX_TransportType, PREFIX_SrcTrunkGroupID;
    PREFIX 0 = *, 10.0.14.3, *, 0, 255, 5060, -1, , -1, , -1, 1;
    PREFIX 1 = *, 10.0.14.3, *, 0, 255, 5060, -1, , -1, , -1, 2;
    [ \PREFIX ]
    ; *** TABLE TrunkGroup ***
    [ TrunkGroup ]
    FORMAT TrunkGroup_Index = TrunkGroup_TrunkGroupNum, TrunkGroup_FirstTrunkId, TrunkGroup_FirstBChannel, TrunkGroup_LastBChannel, TrunkGroup_FirstPhoneNumber, TrunkGroup_ProfileId, TrunkGroup_LastTrunkId, TrunkGroup_Module;
    TrunkGroup 0 = 1, 0, 1, 23, 1000, 0, 0, 1;
    TrunkGroup 1 = 2, 1, 1, 23, 2000, 0, 1, 1;
    [ \TrunkGroup ]
    ; *** TABLE PstnPrefix ***
    [ PstnPrefix ]
    FORMAT PstnPrefix_Index = PstnPrefix_DestPrefix, PstnPrefix_TrunkGroupId, PstnPrefix_SourcePrefix, PstnPrefix_SourceAddress, PstnPrefix_ProfileId, PstnPrefix_SrcIPGroupID, PstnPrefix_DestHostPrefix, PstnPrefix_SrcHostPrefix;
    PstnPrefix 0 = *, 1, *, 10.0.14.3, 0, -1, , ;
    [ \PstnPrefix ]
    ; *** TABLE TrunkGroupSettings ***
    [ TrunkGroupSettings ]
    FORMAT TrunkGroupSettings_Index = TrunkGroupSettings_TrunkGroupId, TrunkGroupSettings_ChannelSelectMode, TrunkGroupSettings_RegistrationMode, TrunkGroupSettings_GatewayName, TrunkGroupSettings_ContactUser, TrunkGroupSettings_ServingIPGroup, TrunkGroupSettings_MWIInterrogationType;
    TrunkGroupSettings 0 = 1, 1, 1, , , -1, 255;
    TrunkGroupSettings 1 = 2, 1, 1, , , -1, 255;
    [ \TrunkGroupSettings ]
    ; *** TABLE ProxySet ***
    [ ProxySet ]
    FORMAT ProxySet_Index = ProxySet_EnableProxyKeepAlive, ProxySet_ProxyKeepAliveTime, ProxySet_ProxyLoadBalancingMethod, ProxySet_IsProxyHotSwap, ProxySet_SRD, ProxySet_ClassificationInput;
    ProxySet 0 = 0, 60, 0, 0, 0, 0;
    [ \ProxySet ]
    ; *** TABLE CodersGroup0 ***
    [ CodersGroup0 ]
    ; ** NOTE: Changes were made to active configuration.
    ; ** The data below is different from current values.
    FORMAT CodersGroup0_Index = CodersGroup0_Name, CodersGroup0_pTime, CodersGroup0_rate, CodersGroup0_PayloadType, CodersGroup0_Sce;
    CodersGroup0 0 = g711Alaw64k, 20, 0, -1, 0;
    CodersGroup0 1 = g711Ulaw64k, 20, 0, -1, 0;
    CodersGroup0 2 = g729, 20, 0, -1, 0;
    CodersGroup0 3 = t38fax, 255, 255, -1, 255;
    [ \CodersGroup0 ]
