3cx VC show state
Discussion in 'Windows' started by asfuture, Feb 4, 2008.
  1. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i have a problem. when i start de Voip Client (v 5.0.3974.0) all the lines, queues and extension are red. if i take a look on de line status on 3cx they are all green. if a place a call from ext 10 on line 10000 become they yellow and after the call are they green. also with another lines, queues, extension. First you have to use it. who can help me???
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello sir
    Please try the latest build of the phone together with the latest build of the 3cx server. The status of the extensions is delivered to the phone by the phonesystem. In other words is mostly the phonesystems responsibility to send it and the 3CX VoIP Client to receive it correctly. There were improvements on both ends so if you upgrade both to the latest version, your problems should be resolved.
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    yes. you are right. now it's working. but i have another question: how i use eye beam or another sip phone in a qeue???
