3CX verion 9.0.13545.594 SP1 Error
Discussion in '3CX Phone System - General' started by sam_atmosphere, Aug 7, 2010.
  1. sam_atmosphere
    Nov 19, 2009
    10
    Hi Guys,
    I am just using the new 3CX verion 9.0.13545.594 SP1 the i tried to update the System Promt Sets while updating i lost my internet connection then it says it failed then i when my internet connection was back online i resume updating but it gives me an message error a 3CX Interface message box says "An exception occurred SysPromptsUpdates Error: Unable to read data from the transport connection: The connection was closed."
    Is it a bug on the new system or just a hiccup. Please help me sort this thing out.
    Sam
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,580
    115
    There's a couple of things you can try out.
    1) Delete the Corrupted download of the prompts and re-download them from the 3CX Management Console. Delete the prompts manually by going here:
    C:\ProgramData\3CX\Data\Ivr\Prompts\Sets
    2) If you cannot download anything on that machine and the error persists, i'd suggest you check whether that machine can connect to the internet at all by visiting a site like http://www.3cx.com on it. If it does have internet, try restarting the entire machine if that's possible.
    - If not, try just restarting the 3CX Services.
