3CX Vers. 15 - Faxserver
Discussion in '3CX Phone System - General' started by ndtk, Sep 9, 2016.
  1. ndtk
    Jul 21, 2016
    we have an Version auf 3CX installed. The OS is Windows 2008R2 Server.
    The System work fine. We have Problems about sending Emails from Faxserver.
    Incomming Calls are accepted, but there is no email is sent. According to report, the sender is the id: fax machine.
    The fax is also received and acknowledged. However, an email comes with the Annex. Emails from the system - but because services do not start or restart arrive. The test mail in the mail settings to come.
    Only by fax - which does not matter.
    At some one an idea? Or grab some still need to adjust?
    Alexander
