3cx Version 11: DNS resolution/Network Failure
Discussion in '3CX Phone System - General' started by adnanj85, Jul 26, 2013.
  1. adnanj85
    Jun 25, 2013
    hi Guys,
    I need an urgent help, all of a sudden my sip trunks have started registering it self and then failing it self.
    It has started from last month and now keeps on bugging every once a week.
    Few days works fine and then again starts giving registration fail DNS/Network Failure issue.
    I have reported My ISP: Response no issue
    Reported Fonet: Response no issue
    Returning Error:
    Event source: 3CXPhoneSystem
    Registration at 7734 **** has failed. Destination (sip:*****@gw1.fonet.dk:5060) is not reachable, DNS error resolving FQDN, or service is not available.
    If i register the same account directly on IP Phone, it gives no error at all, which gives me a conclusion there is nothing wrong with router settings neither the ISP, account registration fails only from 3CX Management Console.
    Please help on it.
    Regards,
    Adnan.
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    @adnanj85
    A Wireshark Capture would help you to understand if the PBX makes a DNS resolution that fails, of if the PBX makes a REGISTER request to the provider that is ignored or refused in some way.
  3. leejor
    11,101
    329
    You could try changing a few settings (depending on how you have it set-up currently) to try to pinpoint the problem.
    Many people simply use their router as a DNS relay, the router usually defaulting to a couple of DNS servers "handed out" by their provider.
    You could try putting the DNS server information into the server/PC running 3CX rather than relaying through the router.
    You could try using another DNS server. A quick search on the net will give you some to try out.
    http://pcsupport.about.com/od/tipstricks/a/free-public-dns-servers.htm
    Google also provides a couple, 8.8.8.8 and 8.8.4.4
    Make note of current settings before changing anything, then, make a change and see if there is an improvement, if not, change it back and move onto something else.
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    @adnanj85
    This is the sort of issue for which 3CX Support exists ;)
