3CX Version ?
Discussion in '3CX Phone System - General' started by gisvpn, Feb 16, 2010.
  1. gisvpn
    Feb 16, 2010
    11
    I hope I am posting this in the right section, apologies if not.
    I am looking to use 3CX with 3 Cisco 7941 phones. I am looking to set them up with my current VOIP provider (voipfone.co.uk) and also access the local PSTN so I am assuming that I can add in a FXO card and set this up. I am not sure if the free edition will achieve this. It mentioned in the product comparison that you cannot SIP Trunk with the free edition, does that mean I cannot connect it to my Voipfone account (just one number and allow the 3 Cisco's to use this SIP line ? These are the questions I think I need help on :
    1. Can I add in an FXO card for local PSTN access (both ways) - can someone recommend one for use in the UK ?
    2. Can I set up 3CX to connect to my voipfone account for calls (both ways)
    3. I will be installing this on Windows 7 Ultimate - is 3CX compatible with this ?
    Many thanks in advance,
    Regards,
    GISVPN
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,893
    192
    You need to use supported hardware and services
    So for a VoIP provider, use a supported VoIP provider in the UK such as Spitfire, VoIp Unlimited
    As a gateway, use a Patton or Grandstream
    As phones, use CISCO SPA phones, not Cisco 7941 phones
    You can do SIP trunking with the free version too. Yes, you can install it on Windows 7.
  3. gisvpn
    Feb 16, 2010
    11
    Hello Nick,
    Thanks for the reply and the information, i'll check out the supproted hardware and services for the voip provider and gateway. With regards to using the Cisco 7941's is there a problem with this. I was hoping to reuse this hardware instead of purchasing some more ?
    Regards,
    GISVPN
  4. Nick Galea
    Jun 6, 2006
    1,893
    192
    You can try to use the CISCO 7941, here is a config guide.
    However its not supported, that is to say we do not regularly re check with the latest firmware nor do our support department support it...
  5. comresource
    comresource Member
    May 22, 2009
    303
    Also keep in mind that the Cisco 7941 even with the SIP firmware will not display BLF information.
