3CX versions
Discussion in '3CX Phone System - General' started by coreybrett, Apr 21, 2010.
  1. coreybrett
    Apr 12, 2010
    72
    According to the 3CX management console, I have 8.0.10116.583 installed, and that it is “up to date”.
    I noticed on the 3CX website, that the build available for download is v8.10824.
    Which is the most current?
    Also, the Phone AutoDetection Update says that it is out of date, but when I press download, it immediately says it is up to date. As soon as I leave the console and come back, it says it's out of date again. Why is this?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    This is a known issue with the version you are using. Kindly upgrade manually to the latest version.
  3. coreybrett
    Apr 12, 2010
    72
    Do I need to uninstall the current version first?
  4. leejor
    10,360
    226
    Yes, I'm sure that if you try to install over a current version it will tell you that you have to delete the one installed. Make sure you do a 3CX back-up (also to a USB stick) first.
