Please say if this is posted elsewhere, I can find it. One big issue with the 3CX Video Conferencing is that you can not test your Audio (and Web Cam) settings before you enter the conference. You then find you are in the conference and they can't hear you, or you can't hear them, or you web cam is pointing somewhere you don't want it to be. Could a box pop open asking you to test and change your settings before you start the conference. WebEx does this very well, you get to hear a sound, if you can't you can change which audio device to use. You can test you mic, by seeing a sound meter (bar) and you get a preview of your Webcam.
Any chance being able to setup recurring Video Conferencing and Audio Conferencing will be included, this would be so great for Team Meetings for example.
This is something that should be suggested under the appropriate thread in the Ideas forum. Meeting creation and scheduling is something handled by the 3CX PBX and not WebMeeting, so this is a completely separate subject/idea from what is being discussed above.
Plz see here and wote if that is what you are looking for: https://www.3cx.com/community/threads/webmeeting-please-add-recurring-meetings.55785/
Yep, i'd suggest you give a comment and upvote to that thread. If it gains a lot of traction, it's something we may consider.
