3cx video call
Discussion in '3CX Phone System - General' started by stash, Mar 12, 2012.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    Anyone tried the video call? what are the configuration need to be done for video calling?
    if i use 3cx softphone nothing happened. if i use x-lite if i press the video it gives me an error failed to start video.
    Thanks,
    STASH
  2. misstake2012
    May 23, 2011
    40
    yes, we use video calls.
    Everything is work fine.
    Check your video codecs.
    Try to establish videocall - (3CX Phone - 3CX Phone)
  3. stash
    stash New Member
    Feb 23, 2012
    213
    Sir Misstake,
    I already tried video call using 3cx to 3cx in the same LAN doesn't work. Even i use x-lite to 3cx i get failed to start video.
    i can't see any logs regarding the video calling. so i don't know where to troubleshoot. do you know how to troubleshoot this problem??
    Thanks,
    STASH
  4. stash
    stash New Member
    Feb 23, 2012
    213
    I also get the video stream will be received on 192.168.xxx.xxx:40000. no video port provided by remote party.when i browse debug in 3cx softphone. anyway to fix this? i think this port is not to be port forwarded right?
    Thanks,
    STASH
