3cx Voicemail Problem
Discussion in '3CX Phone System - General' started by kskstudios, Apr 3, 2008.
  1. kskstudios
    Apr 3, 2008
    Recently changed our mail server to google Apps (Gmail) and I am having problems with 3cx sending voicemails through google. I there a way to hard edit authentication and logging onto smtp server before sending emails. i need to get this problem resolved asap.
    Thanks much for anyones help
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    242
    For mail sending from 3Cx you still need to use the smtp server of the internetprovider where you get your internetconnection from. Most of the time you don't need authentication for that only smtp.xxxxx.com or something.
    for receiving the voicemail you can use your gmail acount. Just fill out that email adress as the adress for voicemail.
    Good luck !!
  3. ess
    ess New Member
    Jun 8, 2007
    133
    I recently made the switch too, and was able to use the actual webhost with V6. However, now in v7, it says it cannot resolve the host in the vbox manager log. The host is smtp.powweb.com:587 . Any ideas?
  4. dmcomputing
    Aug 27, 2008
    14
    Tim
    What is the mail server entry in 3CX? ie is it smtp.powweb.com or smtp.powweb.com:587
    If it is the later, then dns will most likely not be able to resolve it.
    Regards
    Des
  5. ess
    ess New Member
    Jun 8, 2007
    133
    it is smtp.powweb.com:587 . However, if you hover over the question mark for the feature in the management console, it says to enter the address this way. Furthermore, this is how I had it entered in v6.
  6. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    For ythose of you using Google Apps you will need to set your 3CX server to send to one of the MX servers for google. eg: aspmx3.googlemail.com . You do not need to specify credentials for the SMTP connection as long as the domain part of the 'reply address' is the same as the domain part of the destination address.
    Any SMTP server that allows a MAIL FROM containing yourdomain.com will be able to process the emails from the 3CX server. If you are running a mail server inhouse point 3CX to it and avoid sending the emails out to an external source.
    If you have issues with SMTP based issues, you shoudl recheck the SMTP settings and enable the 'notify user when extension created', then create a test extesnion and see if the mail is received. Furthermore ensure that MAV and MP3 files are not blocked by a corportate email filter of some type.
    For those running non port 25 mail servers, please confirm if the mail server is seeing the connection.
  7. libnat
    Oct 21, 2009
    Thank you so much, this worked perfect for us!!
  8. Patrick Heeney
    Sep 28, 2012
    Can you give an example of the mail setup above to make it clear to me.
    I am using my own domain name in google apps.
    I realise this is an old thread but as I am a new user it would be much appreciated.
    Regards
    Patrick
  9. bobsplat
    Oct 11, 2012
    I'm having the same problem.
    I've entered
    Mail Server: aspmx3.googlemail.com (without a trailing dot)
    Reply Address: myname@mydomain.com
    User name for SMTP server: myname@mydomain.com
    Password: my password
    The email fails when setting up a test extension.
    I'm using the free edition but cant find any specific reference to this function being unavailable.
    Help anyone?
