3CX VOIP Client and conference
Discussion in '3CX Phone System - General' started by radix, Feb 5, 2008.
  1. radix
    Feb 5, 2008
    23
    At the moment we're planning to migrate from Swyx to 3cx proffesional.
    I've installed on a test server and everything looks very promising.
    The only feature which bugs me and can be a real stop for this project is the ability to make conference calls via 3cx client.
    I've tried the x-lite client which works ok but this client is not supporting TAPI so is a no go for us.
    My question is, how can I make a conference call with the 3cx client? I could find no options for that (maybe I'm blind :) ).
    If it is not possible not even in the near future, is there another voip client that can do TAPI and conference calls? Both criteria are KO criteria.
    Yeah.. if the client is free is even better. (one of the reasons to migrate from swyx->3cx)
    Cheers,
    radix
    P.S. Also planing on buying a patton 4554 for the begining. There are some known issues with this device or it is ok?
  2. radix
    Feb 5, 2008
    23
    Hmm.. nobody is using the 3cx client?
    There are better ones? Sorry for the questions but I'm new to the 3cx products.
    Cheers,
    radix
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    see the anouncement of the 5.1 version, wait for the next 3CX VOIP client
    regards
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We're going to add conferencing quite soon, and not only for VoIP CLient, but also for any SIP phone.
    Patton is really good device, though far from trivial in configuration.
  5. radix
    Feb 5, 2008
    23
    Thanks for the answers!
    @aguilar: do you know where I can find the announcement for 5.1?
    @archie: good to hear it!
    Cheers,
    radix
  6. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    http://www.3cx.com/forums/3cx-phone-system-v5-1---beta---build-3793.html
