3cx voip client on HTC Evo (Sprint)
Discussion in '3CX Phone System - General' started by scholarlv, Jul 7, 2010.
  1. scholarlv
    Jul 7, 2010
    Ok I got this client working better than SIPDroid. the only problem i have is that there is NO mute function in the client. I use this method because I need to do a lot of conference calls for work which eat up my minutes. I have unlimited mobile to mobile calling and data.
    Could someone please tell me how to the 3cx client on mute..
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    I don't think it's there.
  3. evotivo
    Jul 21, 2010
    scholarlv -
    Can you please post how you got this to work on EVO? My 3CX client registers fine and looks like everything is working but the call goes nowhere when I dial out. I am using pbxes.org as my server.
  4. jamesdean
    Oct 20, 2010
    Are there any plans to support 4G with 3CX on the EVO? While on the 4G network I cannot place a call. It acts the same as if you have enable 3G unchecked and not on wifi, it will register, let you dial the number but not place the call.
