3CX Voip Client SIP/RTP Tunneling Proxy fail to start
Discussion in 'Windows' started by SoftLa, Nov 25, 2008.
  1. SoftLa
    Nov 25, 2008
    I've encounter "3CX Voip Client SIP/RTP Tunneling Proxy fail to start" when i was installing the client on my computer. Has anyone encounter this B4??
    I'm using 3CX V6 client and running on Windows XP SP3.
    Thx.
  2. yannl
    Apr 17, 2008
    I have the same problem. The service crashes during install.
    Error message detail:
    Tunneling proxy crash:
    Problem Event Name: APPCRASH
    Application Name: 3CXTunnel.exe
    Application Version: 6.0.3545.0
    Application Timestamp: 49130281
    Fault Module Name: LIBEAY32.dll
    Fault Module Version: 6.0.6001.18000
    Fault Module Timestamp: 4791a7a6
    Exception Code: c0000135
    Exception Offset: 00009cac
    OS Version: 6.0.6001.2.1.0.256.6
    Locale ID: 4108
    Additional Information 1: 9d13
    Additional Information 2: 1abee00edb3fc1158f9ad6f44f0f6be8
    Additional Information 3: 9d13
    Additional Information 4: 1abee00edb3fc1158f9ad6f44f0f6be8
    I tried to install it using the command line, same result.
    I'm running Windows Vista Business, all patches installed to date.
    Help would be greatly appreciated
  3. hazet
    Jun 22, 2007
    8
    Same problem ! running Vista Business
    regards
    henk
  4. ikroumov
    Nov 26, 2008
    Same problem during the installation on VISTA x32 Ultimate
  5. scwhittle
    Nov 29, 2008
    Any one got a beat on this? Very frustrating!
    Version 6 loads and works, although I can't get the tunnel to work
    Version 7 bails with the SIP/RTP Tunneling Proxy - running XP pro
  6. auberge
    Nov 30, 2008
    The same error on some PCs while installing.
    Reason: 3cxTunnel.exe won't start because of 2 DLLs are absent on these PCs (libeay32.dll, ssleay32.dll). Both are located in [windows]\system32.
    Walkaround: find 2 DLLs on PC where it works and copy them in [windows]\system32 folder of PC with error. They do not need to be registered - just copy them. And run installer after that.
    Hope 3cx will fix this bug in installer in next releases.
  7. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    The client build uploaded on the release of V7 addresses this issue.
    Please advise should you still be encountering this.
  8. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,972
    283
    I also suggest trying out he beta of the new softphone which is easier to configure
