3CX Voip Client Uninstall Stuck
Discussion in '3CX Phone System - General' started by qaisdev, Aug 11, 2008.
  1. qaisdev
    Apr 7, 2008
    33
    I am trying to uninstall the 3cx voip client but all the time it is failing and throws error , package not found or somthing like it.
    Is there any way to uninstall it manually.I am trying to install the laterst one but it fails as well b'coz it is trying to uninstall the previous version.
    Any help will be really appreciated.
    Kind Regards
    Qais
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    You can try using the Windows Installer CleanUp Utility that maybe be found on http://support.microsoft.com/kb/290301
    regards
    Alex Mallia
    3CX - Developers of IP PBX software
    http://www.3cx.com
  3. qaisdev
    Apr 7, 2008
    33
    Thx It works
