3CX VOIP Client v6.0 available
Discussion in 'Windows' started by ra81, Apr 15, 2008.
  1. ra81
    Oct 24, 2007
    8
    We have released a new version of our VOIP Client, version 6.0
    Please download it from here:
    3cx.com/downloads/3CXVoIPClient6.msi - NO LONGER AVAILABLE TO DOWNLOAD
    Build history is available here
    We look forward to your feedback!
  2. iglezos
    May 6, 2008
    Re: 3CX VOIP Client build 4492 available
    I have a win vista ultimate x64 and i have already installed the v4316 client version.
    I downloaded the 4492 and when i install it gives an error 2738 and the installation is aborted.
    What is the problem??
  3. swanny
    May 17, 2008
    I have found a Bug in the Client v4492 when 3CX Tunnel is configured.
    How do i report it if i have no support.
    I am getting excessive traffic as soon as my pc starts up, wireshark capture attached.
  4. jcru
    Apr 22, 2008
    12
    When i install 3CX VOIP Client v6.0 build 567, the status of all 3cx clients are grayed out, instead of green or red.
    why?
  5. sistemi
    May 23, 2008
    I have a win vista business x32 and i have already installed the v5.0 client version.
    I uninstall v5.0 and downloaded the latest vaersion and when i install it gives an error 2755 and the installation is aborted.
  6. Discovery Technology
    Apr 19, 2008
    278
    I doubt that it was the V6 client that was the cause of the error as most 3CX upgrades are done the way you described.
    Here's a link where the solution was to remove NTFS file encryption on temp and install folders:
    http://www.pcreview.co.uk/forums/thread-1701607.php
    Another where encryption was the culprit:
    http://www.pcreview.co.uk/forums/thread-2177352.php
    Check these out and see how you go.
    Cheers, Brendan
  7. robertmacp
    Oct 30, 2008
    Is there a way to lower the ringer or silence it? Also some calls are very low and hard to hear, is there a way to increase the volume of the call?
  8. Jack Karl
    Apr 12, 2009
    Hey thanks for the referenc to download VOIP, Cheers to you buddy,
  9. daless
    Jun 26, 2009
    Thanks for the download. Much appreciated!
  10. Cass Ibbie
    Jul 1, 2009
    Similar to 410, but using a backlit 320x240 pixel LCD. The phone has both a UP0 ISDN interface and a LAN connection for use as an IP phone. A SIP version is available, the firmware image is available for download. From the datasheet:
    "Compatible and flexible SIP phone supporting both standard SIP as well as Siemens SIP implementations plus 3rd party SIP server feature enhancements
    * Extra-large back-lit display with touchscreen functionality, graphics capability
    * Local electronic notebook allows for fast, convenient access to personal contact details
    * Access to corporate directories via standard LDAP protocol
    * WAP browser to access to business-related information in WML format
    * Quality of Service (QoS) provides excellent LAN voice quality
    sip dll
