3cx Voip clilent - Version 5
Discussion in '3CX Phone System - General' started by gr2010, Dec 17, 2007.
  1. gr2010
    Dec 11, 2007
    27
    I am not able to login 3CX Voip cllient to 3cx system server. I am testing out internal extensions. It gives me not connected message in the client. I never got connected after installing the server and client. server seems to be working correctly. I have installed extensions and I am using one of the extensions at my client. Pl. let me know if I need to fine tune some where to get connected to server to test extensions. .. thanks
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi.
    First of al.. Think this tread should be in Client Beta General forum... :wink:
    But..
    Do you have the client in Deskphone mode, or headset mode?
  3. gr2010
    Dec 11, 2007
    27
    I am sorry to post here. It is head set mode
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    No prob... :)
    If headsetmode is choosen you might want to review login settings, including default settings, like PQDN/IP to server and so on...
    This is found under File -> Settings
  5. gr2010
    Dec 11, 2007
    27
    I want to make sure my settings are correct:-
    SIP PORT: 5060
    FIRST RTP PORT: 7000
    LAST RTP PORT: 7499
    TAPI PORT: 4300
    STUN SERVER: stun.3cx.xom
    or Do you want me verify any thing at serve to cross the above
  6. Mori
    Mori New Member
    Mar 23, 2007
    223
    If this is your settings defined i 3cx box.
    Also check that the IP for your 3vc box is propper defined in the client...
  7. gr2010
    Dec 11, 2007
    27
    where do I check IP in the sever. just to make sure client setting is correct and also do I have to use the port number at the end in the client after ip address: for ex: http://192.168.2.103:5481/
