3CX voip phone and assistant web page reports
Discussion in 'Windows' started by dhedges, Oct 28, 2009.
  1. dhedges
    Oct 28, 2009
    just installed 3cx last night and quite impressed with it.
    I connected it to a sipgate number without any problems and was able to receive phone calls within a few minutes of install.
    I am having a slight issue at the moment with regards to the web page reports which you can get to via the 3cx assistant 'MyPhone' menu option.
    The web pages display and I can see the different tabs, I can change my status etc....
    The problem I have is that while I can see additional 'rows' appearing for such things as received calls, voice mails etc... the lines are completely blank with no call info text at all. It will let me select the lines and voicemail will evne try and play it back (although nothing plays) yet they are just blank lines.
    If I look on the phone itself then that correctly shows all the CLI info, date / time etc... and also plays voicemails without any problem.
    Any ideas ?
  2. comresource
    comresource Member
    May 22, 2009
    303
    Make sure the MyPhone page is in your trusted sites page if you are using IE. You also may need to lower the default security settings for this zone.
