3CX VoIP Phone and Cisco Call Manager
Discussion in 'Windows' started by DShadow, Apr 13, 2010.
  1. DShadow
    Apr 13, 2010
    Hi there!
    I was wondering if it is possible to integrate 3CX VoIP Phone with Cisco Call Manager (System version: 6.1.2.1000-13).
    Thanks,
    Mihai
  2. comresource
    comresource Member
    May 22, 2009
    303
    Yes, this should be possible.
  3. hgcomp
    Aug 7, 2008
    33
    THINK IN TRUNKS AND DID'S THIS IS THE ANSWER
    SALUDOS.
  4. DShadow
    Apr 13, 2010
    Thanks for the quick answers. I have searched the net for some tutorials or some documentation but I did not find any. Can you please put a link here or describe how can it be done?
    Thank you,
    Mihai
  5. comresource
    comresource Member
    May 22, 2009
    303
    This may help
    https://learningnetwork.cisco.com/docs/DOC-3886
  6. jelleb
    May 3, 2010
    As I am currently using 3CX in our lab for testing some things including integration with a call manager infrastructure I can say the server to server communication is a bit cumbersome.
    However after some digging I can use the 3cx softphone client as a sip client to call manager with no apparent draw backs.
    Mind you however I use 3cx only in the lab currently.
    Key is authentication :)
  7. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If you will follow the idea:
    then server to server will be the "piece of cake" :)
