3cx VOIP Phone Call Transfer
Discussion in 'Windows' started by inibiru, Jul 20, 2012.
  1. inibiru
    May 10, 2012
    9
    Hello, I have a user who's phone when calls are being transferred to her the call goes straight to voicemail even though she is all green lights. I was wondering about any trouble shooting steps I can do to fix this. I have tried reinstalling the phone I have checked all her settings serverside and everything seems fine.
    10,365
    227
    What does the 3CX log show, when a call is attempted to her extension? Does the same thing happen when you call the extension directly from another extension, or does the call behave differently than a transferred call?
  3. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    you can configure in windows e.g. DSCP for some particular apps...
    http://forums.speedguide.net/showthread.php?274421-Windows-7-resets-DiffServ-%28DSCP%29-to-0x00
  4. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    sorry, replay befrore was for some other topic..
    can you put some logs as leejor said, 3cx logs, wireshark, is that only with local calls or every call
  5. qiaok
    Jul 23, 2012
    What does the 3CX log show?
    Image no longer available
  6. inibiru
    May 10, 2012
    9
    Sorry about not getting back to you guys soon enough I was on vacation here. When I go into the server and watch the log I can't seem to recreate the issue however when I was doing this I noticed that this Error kept popping up.
    13:34:10.084 [MS105000] C:8740.1: No RTP packets were received:remoteAddr=192.168.2.161:5008,extAddr=0.0.0.0:0,localAddr=192.168.2.140:7220
    Could this have anything to do with it?
  7. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    That could be the issue however it looks like that error is due to no voice/media packets being received by the softphone. Could you replicate and post more of the log?
  8. inibiru
    May 10, 2012
    9
    Ya here is a Log of one that I caught:
    15:03:18.603 [CM503008]: Call(15132): Call is terminated
    14:58:38.811 [MS105000] C:15132.1: No RTP packets were received:remoteAddr=192.168.2.161:5008,extAddr=0.0.0.0:0,localAddr=192.168.2.140:7146
    14:58:38.093 [CM503007]: Call(15132): Device joined: sip:101@192.168.2.32:51488;rinstance=a61aef7841bd7467
    14:58:35.452 [CM503025]: Call(15132): Calling Ext:Ext.101@[Dev:sip:101@192.168.2.32:51488;rinstance=a61aef7841bd7467]
    14:58:35.405 [CM503004]: Call(15132): Route 1: Ext:Ext.101@[Dev:sip:101@192.168.2.32:51488;rinstance=a61aef7841bd7467]
    14:58:32.062 [MS105000] C:15132.1: No RTP packets were received:remoteAddr=192.168.2.161:5008,extAddr=0.0.0.0:0,localAddr=192.168.2.140:7140
    14:58:30.515 [CM503007]: Call(15132): Device joined: sip:*0@127.0.0.1:40000;rinstance=d7a0dcfb2dd3867b
    14:58:30.312 [CM503025]: Call(15132): Calling Ext:Ext.*0@[Dev:sip:*0@127.0.0.1:40000;rinstance=d7a0dcfb2dd3867b]
    14:58:30.296 [CM503004]: Call(15132): Route 1: Ext:Ext.*0@[Dev:sip:*0@127.0.0.1:40000;rinstance=d7a0dcfb2dd3867b]
    14:58:01.406 [CM503007]: Call(15132): Device joined: sip:999@127.0.0.1:40600;rinstance=eabd1c034ce5a486
    14:58:01.250 [CM503025]: Call(15132): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=eabd1c034ce5a486]
    14:58:01.187 [CM503005]: Call(15132): Forwarding: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=eabd1c034ce5a486]
    14:58:01.187 [CM503016]: Call(15132): Attempt to reach <sip:170@127.0.0.1:5060> failed. Reason: Not Registered
    14:58:01.187 [CM503017]: Call(15132): Target is not registered: Ext.170
    14:57:35.172 [CM503007]: Call(15132): Device joined: sip:999@127.0.0.1:40600;rinstance=eabd1c034ce5a486
    14:57:35.016 [CM503025]: Call(15132): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=eabd1c034ce5a486]
    14:57:34.969 [CM503005]: Call(15132): Forwarding: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=eabd1c034ce5a486]
    14:57:34.969 [CM503003]: Call(15132): Call to sip:101@192.168.2.140:5060 has failed; Cause: 486 Busy Here; from IP:192.168.2.32:51488
    14:57:34.797 [CM503025]: Call(15132): Calling Ext:Ext.101@[Dev:sip:101@192.168.2.32:51488;rinstance=a61aef7841bd7467]
    14:57:34.750 [CM503004]: Call(15132): Route 1: Ext:Ext.101@[Dev:sip:101@192.168.2.32:51488;rinstance=a61aef7841bd7467]
    14:51:18.726 [CM503007]: Call(15132): Device joined: sip:120@127.0.0.1:51901;rinstance=c67b9c580b8dad14
    14:51:12.367 [CM503025]: Call(15132): Calling Ext:Ext.120@[Dev:sip:120@127.0.0.1:51901;rinstance=c67b9c580b8dad14]
    14:51:12.320 [CM503004]: Call(15132): Route 1: Ext:Ext.120@[Dev:sip:120@127.0.0.1:51901;rinstance=c67b9c580b8dad14]
    14:51:02.867 [CM503007]: Call(15132): Device joined: sip:101@192.168.2.32:51488;rinstance=a61aef7841bd7467
    14:51:02.695 [CM503025]: Call(15132): Calling @[Dev:sip:101@192.168.2.32:51488;rinstance=a61aef7841bd7467]
    14:50:57.883 [CM503007]: Call(15132): Device joined: sip:807@127.0.0.1:5488
    14:50:57.727 [CM503025]: Call(15132): Calling Ext:Ext.807@[Dev:sip:807@127.0.0.1:5488]
    14:50:57.664 [CM503004]: Call(15132): Route 1: Ext:Ext.807@[Dev:sip:807@127.0.0.1:5488]
    14:50:28.477 [CM503007]: Call(15132): Device joined: sip:812@127.0.0.1:40600;rinstance=21080f7f6ea3ed4a
    14:50:28.477 [CM503007]: Call(15132): Device joined: sip:10014@192.168.2.161:5064;transport=udp
    14:50:28.321 [CM503025]: Call(15132): Calling Ext:Ext.812@[Dev:sip:812@127.0.0.1:40600;rinstance=21080f7f6ea3ed4a]
    14:50:28.274 [CM503004]: Call(15132): Route 1: Ext:Ext.812@[Dev:sip:812@127.0.0.1:40600;rinstance=21080f7f6ea3ed4a]
    14:50:28.274 [CM505002]: Gateway:[GXW4108 192.168.2.161] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4108 (HW 1.1, Ch:1) 1.3.4.10] PBX contact: [sip:10014@192.168.2.140:5060]
    14:50:28.258 [CM503001]: Call(15132): Incoming call from 5307106890@(Ln.10014@GXW4108 192.168.2.161) to <sip:812@192.168.2.140:5060>
    I grabbed everything that had to do with that specific call. There were a few calls being taken place during this call and I didn't grab that info. If you want I can grab the full log next time but I figured this would do.
  9. inibiru
    May 10, 2012
    9
    Edit: It was during the call transfer between extension 120 and 110 that the caller was sent to the Voice mail system just to be clear
  10. leejor
    10,365
    227
    Did you mean ext 101?
    Is this the log of the failed call ? If so then for some reason, 3CX sees the extension as being busy at the time of the call.
  11. inibiru
    May 10, 2012
    9
    Do you have any idea how that could happen? Obviously the Extension isn't busy during that time frame.
  12. jpillow
    Jun 20, 2011
    1,342
    Have you also checked the web GUI to assure the phone isnt set to auto answer?
  13. jpillow
    Jun 20, 2011
    1,342
    set phone to fascatory default reboot the phone than reconfigure/provision.
