3CX VOIP phone ver. 3 crashes on Windows 2K
Discussion in 'Windows' started by bgibbs85, Sep 2, 2009.
  1. bgibbs85
    Sep 2, 2009
    I can get 3CX VOIP phone to install and run perfectly on Windows XP systems on my network, but any time I try to install it on a Windows 2000 system (and they're all SP4 systems), I get this error:
    3cxphone.exe has generated errors and will be closed by Windows. You will need to restart the program.
    An error log is being created.
    Any idea on how to fix this?
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    If you have the resources available to upgrade to a modern OS I would highly recommend you do so. While Windows 2000 was a great operating system, it hasn't been actively supported by Microsoft since late 2004. I have seen 2000 machines become compromised within 20 seconds of being attached to a internet connection.
    However if you can't, look in the event log and see what error it threw and post it here.
  3. spinnerfarm
    Sep 4, 2009
    28
    I have the same problem, works great on XP but not on 2000 (wife pc is 2000 and she likes it and is worried about upgrading). Where is the event log stored bucasue i have not been able to find it.
    Steve
  4. tpinnovations
    Jul 30, 2009
    296
    http://support.microsoft.com/kb/302542
  5. spinnerfarm
    Sep 4, 2009
    28
    So, i start the softphone. It shows trying to connect.
    then it ends and a box says creating error log
    I go to events, applications and i find two entries for 3cx
    the first says initializing core elements
    the second says opening application window.
    That is it. Nothing else.
    is the softphone supposed to work on win 2K (sp4 is what I have).
    Steve
  6. tpinnovations
    Jul 30, 2009
    296
    I would not expect it to work on 2000, You may wish to await for official word from 3CX.
  7. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    If you read the prerequisites for installing 3CX it clearly states XP Pro as the minimum OS required so Windows 2000 is not supported.
  8. tpinnovations
    Jul 30, 2009
    296
    ^ Ahem..
    http://www.3cx.com/VOIP/softphone.html
  9. tpinnovations
    Jul 30, 2009
    296
    Have you tried the new version 4 phone on windows 2000?
  10. spinnerfarm
    Sep 4, 2009
    28
    Yes, just did. Exact same problem.
    Steve
  11. tpinnovations
    Jul 30, 2009
    296
    1. You have the latest .net framework? (3.5)
    2. You have all the latest updates from MS to date.
    Beyond that, I think the only option is to upgrade to XP.
  12. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,446
    61
    Definitely 3CX Voip PHONE will NOT work on a Windows OS lower than XP.
    The mention of Windows 2000 OS in http://www.3cx.com/VOIP/softphone.html (pointed correctly by tpinnovations above) has been valid for 3CX Voip Phone's predecessors, which are no longer supported, so we will have to update that page - thanks tpinnovations.
    Also, 3CX Voip Phone (like its predecessor) doesn't use .NET Framework.
    Regards
    vali
  13. spinnerfarm
    Sep 4, 2009
    28
    Upgrading wifes laptop to XP right now.
    Thanks for all the answers and help on this.
    Steve
  14. Vali_3CX
    Dec 12, 2008
    1,446
    61
    We also removed the Win2K from the list of phone's supported OSs.
  15. Spider star
    Oct 7, 2009
    I agree 3CX works really well on XP but getting problem on 2000.I am also looking for the solution for that.Can any one got a good one.
  16. tpinnovations
    Jul 30, 2009
    296
    Your only option is to upgrade to XP.
  17. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    This is unsupported. We cannot support a 10 year old operating system. At some point we have to draw a line.
    We are talking about an OS that has was released in the year 2000 - 10 years ago.
