3CX VoIP Tunnel mandatory?
Discussion in 'iOS' started by chikara sugiyama, Aug 18, 2014.
  1. chikara sugiyama
    Jun 15, 2014
    22
    Hi there
    We would like to use the iPhone from a remote environment.
    3CX VoIP Tunnel or required for it to be set in the iPhone?
    3CX VoIP Tunnel Do you support auto provisioning?
    Do not be completed in a single application as Android?
    Please check.
  2. roland_3CX
    roland_3CX Support Team
    Staff Member
    Mar 28, 2014
    131
    7
    Hi flatapi,
    No it is not mandatory but it is recommended. It is advised to turn this option on to avoid intermittent connection. Yes you can provision your 3CX iphone client via email. If you choose to use the Tunnel then you will have to download the 3CX tunnel (separate App) from the app store.
  3. chikara sugiyama
    Jun 15, 2014
    22
  4. chikara sugiyama
    Jun 15, 2014
    22
    Can I e-mail the provisioning 3CX tunnel?
    And I tried several times, but it can not be provisioned in the mail.
  5. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    Please note that you cannot provision the tunnel via the welcome email as the 3CX tunnel is a separate application. You will have to open the 3CX Tunnel App and fill all the required fields in order for the tunnel to connect.
    Best Regards
