3CX VPN
Discussion in '3CX Phone System - General' started by asimpson, Aug 29, 2008.
  1. asimpson
    Aug 27, 2008
    7
    What hardware is required to connect to 3CX VPN (don't want to use a pc)? I'm wondering what router requirements are needed to connect a router at a remote office to 3CX VPN.
    Particularly, I was also trying to figure out if a Linksys SPA-3102 might work since it is both a router and FXS/FXO gateway. But, I'd be willing to look into other hardware. I'm wanting the router to constantly maintain the remote connection so I can have IP phone(s) at the remote location via the 3CX VPN.
    Does anyone know?
    Also, feel free to recommend other hardware to accomplish this.
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    In A good price and quality
    you can choose netgear,linksys or dlink
    If you use DSL I prefer to all in one router (mode,router and firewall)
