- Joined
- Jun 11, 2008
- Messages
- 108
- Reaction score
- 0
3CX Web Informer, now your website visitors can see the status of external phoneу lines .
- Display information in real time
- Inbound, outbound calls, queues, and calls on hold
- Easy setup in 5 minutes
- You can embed it into any website in PHP
- Free
Download http://icepartners.ru/file/webinformer/3cx web informer.zip
Setup 3cx web setup.exe on a 3CX server. (Note- application work only on commercial versions of 3CX)
Check in Services that 3CX WEB Informer service is running.
If not running check path in Windows Register
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\3CX Web Informer
Bind port 5150 to the external IP to the server 3CX.
Copy the contents of the archive web-client.zip to your web-server to a separate folder.
In the file informer.php change the next settings
Go to http://website.com/folder/
You should see the following
Additional configuration
index.html
update time
informer.php
- Free
Code:
line 12 $ line_num = 3; / / Total number of external lines
line 13 $ address = '11 .195.131.150 '; / / Your 3CX server IP address
index.html
update time
Code:
string 25 - setInterval('show()',1000);
1000 - 1 second
Code:
string 12 $line_num = 3; //Total number of lines
string 13 $address = 'XX.XX.XX.XX'; // 3CX server IP address
string 14 $port = 5150; // Informer's port, DO NOT CHANGE IT!!!
string 15 $buzy_btn = 'button_red.png'; // Button for busy line
string 16 $free_btn = 'button_green.png'; // Button for free line
